What happen with "Editor-Shaping"?
jesuschoyjesuschoy Posts: 57
In the scene (see figure) I have the "Basic Male genesis", and in "Editor-Shaping" only appears his morph, the others morphs disappeared.
When I load another item, is the same, only appears his respective morph.
In this point, DS4.6 don't work like DS4.5?
What can I do?
937 x 695 - 101K
  • Richard HaseltineRichard Haseltine Posts: 111,992
    Are you using the latest version of Genesis Starter Essentials and any morph packs? The oldest versions did have a problem with the way they were set up that caused them not to appear in the Shaping pane (though they were in the Parameters pane OK).
  • jesuschoyjesuschoy Posts: 57
    edited July 2013
    I uninstalled and installed both, DS4.6 and Genesis Starter essentials (re downloaded from Daz site).
    The result is the same.
    856 x 905 - 111K
    Post edited by jesuschoy on
    The path ought to be right or you wouldn't see Genesis at all, but check that the folder you are installing the content to is listed in the Content Library pane under DAZ Studio Formats.
    Thanks for all.
    Apparently by mistake I deleted the address, all is working now.
