Auto created custom action does not found the .duf file ...
Hello,
I do this :
1 - In a custom libriray where I have defined some poses, in right click on one of them and chose "Create custom action".
2 - I have the confirmation that the custom action is created and visible in the "Scripts" menu.
3 - In the script menu I choose that script and I have an error message saying that the file is not found even it the path showed is correct.
Of course, if I select the pose in the custom library all is working smoothly
I've checked the file path and name and it's the good one.
Where is the problem ? Where can I found more information to solve it ?
Thank for your help.
Michel
  • Richard HaseltineRichard Haseltine Posts: 111,348
    One thing to check might be that you don't have nested content diectories (one content directory inside another).
  • One thing to check might be that you don't have nested content diectories (one content directory inside another).
    Hello Richard and thank for you reply.
    Not at all, all content directories are different and not nested.
    Michel.
    What is the location of the file? How was it installed?
  • The one I tried is in X:/DAZ 3D/Studio/Working Library/Presets/Poses/Default/global.duf. X:\ It's on a HD on the same computer. C:\ is a SSD and I spare place on it.
