G3 to G8, eyelashes on wrong place, how to fix?
I decided to take a stab at converting some of my G3 figures to G8 and thought it went great until I realized the eylashes were not in the correct place. I read about enabling autofollow on the morph itself so I enabled that by locating the morph in parameters/morph loader, edit mode, enable auto follow, but the eyelashes did not correct (I also set teh eyelashes to autofollow rather than redirect transforms, still nothing). Then I read that maybe I need to save the morph as a morph asset and reload it, so I tried to do that but I cannot find any saved morph asset after I do that, so I cannot figure out how to reload it. I am saving it to the same location as usual, a My Library folder where all my personal presets etc are, but when I save the morph as an asset it is as if nothing is happening as far as I can tell, there is no morph asset folder, there is no files loose in the library folder where the save dialogue is pointing, a manual browse to that location shows nothing nor in the daz content library for that location. I assume I am overlooking something but I have no idea what, any step by step, how to save my morph as a morph asset that I can then find and reload would be greatly appreciated. Thanks!
  • gederixgederix Posts: 392
    Never mind, figured it out.
    OK I thought I had it figured out but no. I can load the character morph(s) onto a g8 figure, apply it, and everythings fine, eyelashes following morph. Save scene, close, reopen, eyelashes no longer following. What am I missing???
    I am going to go back to square one and start over, completely from scratch and see if I cant get this working but if anyone has any input into what it is you suspect I am messing up Id very much appreciate some insight, thanks! I have to manually reload the morphs every time as a workaround -- zero figure, base, zero sub, delete morph, reload w morphloader, apply, works great, lashes and all, but have to redo this every time, obviously not going to work.
