How do I convert wavefront OBJ files to genesis 2 female compatible clothing with autofit?
How do I convert a wavefront OBJ files to genesis 2 female compatible clothing with autofit? I choose 'save as support asset' and then the "figure/prop asset". I set the content type as follower/wardrobe. I set the category as default/figures/people/female. I set the compatibility base to genesis 2 female as well as the 'compatible with'. But when I add the prop to my scene there is no autofit option.
  • WilmapWilmap Posts: 2,917
    Did you use the transfer utility to set the item to the figure? This will add the bones to the item which match the figure.
  • brckbrdbrckbrd Posts: 15
    Is the transfer utility part of the Daz3D program? If not where can I get it?
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Edit>Figure>Transfer Utility, set the Source to the figure the clothing is made for, set the Target to your imported OBJ.
    Thank you for that info, I got it figured out.
