Questions re adjusting lighting with Iray HDR
dracorndracorn Posts: 2,353
1.  How do make adjustments to the lighting color while using an HDR?
For example, I'm using Skies of Iradiance https://www.daz3d.com/skies-of-iradiance-sunset-hdris-for-iray
I love the sky color, but it saturates the environment with too much orange.  How do I calm that down - I can't find a temperature adjustment on the Render tab.
2.  Is there a way to use one sky so I can see it in the background while using a different environment (or maybe combine the two?)
  • FishtalesFishtales Posts: 6,212
    The only thing I can think of is to lower the White Point or use a white Distant Light pointing from the front to soften the orange light.
  • dawnbladedawnblade Posts: 1,723
    For #1, in Tone Mapping, try Burn Highlights 0 and Crush Blacks .25 or higher. This will affect your entire render though, not just the HDRI.
    If you have Tonal Rage, there are presets for a muted look that change those two properties. That's how I got those values.
  • dracorndracorn Posts: 2,353
    Thanks for the tips; I will experiment.
    What do you use to add a little extra light to highight a face?
    For extra light on an object I would use a spotlight set to Disc or Plane and adjust the size or use a Primitive Plane set to Emissive and use it like a reflector.
    Thanks Fishtales.  I will try that as well.
