Smoothing modifier
Hello , I have a problem with smoothing modifier . If someone could help me with it. I try to pose figure on bed and use modifier on that and its not a problem the blanket/duvet is fine and I can adjust it fairly easily but when I try to add another figure to collide with blankt/duvet and I change the collision item it restores the first figure to default without collision and I dont know how to add two items to collide at the same time or somehow memorize the first one so I can pose the second one and have collided both.
  • Richard HaseltineRichard Haseltine Posts: 111,958
    There can be only one collision target. I can see a couple of possible ways around this - either export all the stuff you want to collide with as a single OBJ (hide everything else, File>Export, set the format to OBJ, Daz Studio preset, then File>Import, select the OBJ, Daz Studio preset) and use that as the (hidden) collision target or, if the mesh is suitable, apply a dForce modifier to the blanket and simulate it to drape over the figures and the bed.
  • VEGAVEGA Posts: 86
    The first one solves the issue , but after that export I cant acces figures individualy . Is there any way around that ? If not then its okay with the first one. I know about the dforce simulation but in my case the blanket needs to be under. But then again thanks for the solutions.
