System 50
Hi,
Has anyone managed to get system 50 to work?
I tried System 46 and really liked it, but for some reason system 50 doesn't work. When you click on a material it just removes half of the suit and destroys half the face.
I've tried loads of things to no prevail.
Any advice would be great.
Thanks
1092 x 788 - 60K
1046 x 747 - 55K
    edited May 2018
    @Deanpw
    You need to select the suit part in the Scene Tab, then apply the material. I started with an empty scene , then chose System 50 Half Human. If you apply a material with the figure slected, you will get your results.
    If you just select the suit, you will get what you want. See the attached screen caps.
    650 x 278 - 13K
    689 x 849 - 137K
    650 x 596 - 279K
    Post edited by fastbike1 on
  • DPWDPW Posts: 267
    Thanks for your comment. It still doesn't work unfortunately. When I've selected the Half human, and it loads into the scene, it's not picking up the system 50 at all. It says genesis 3, even though I'm trying to select the outfit. It's not in the scene.
    Any more advice would be appreciated.
    Thanks
    1267 x 486 - 65K
  • DPWDPW Posts: 267
    It's ok, cracked it thanks! Didn't realise it was a drop down in scene mode :)
    Thank you for your help fastbike1! Really greateful!
    Cheers,
    Dean
