Dynamic Supersuit set 1 problem
TY3DArtTY3DArt Posts: 164
I am unable to add the suit to my character. The suit is added on to the scene but it is no visible or tangible. I am unable to view or add materials. I am trying to create a "Batman" outfit and it is now working. The suit does not show up in on the body or anywhere on the scene. I looked up a few videos on youtube and I am adding the suit on correctly but there is nothing there.
    Does anything appear in the Scene tab to that extent? If so, you should be able to select it and then use the framing tool in the viewport to center your camera on it (use the perspective camera so you don't mess up any existing cameras). If it doesn't appear then it hasn't loaded correctly. There are a number of reasons why this might be, namely missing files or (a common mistake) loading in a materials preset instead of the actual model.
    Lastly, if it does load and the camera centers on it then it could be either incorrectly scaled or obscured by the figure.
  • LindseyLindsey Posts: 2,017
    edited July 2013
    I have the product, but have little experience using it so I'm in the same boat as you. First of all, this product is designed to be used with the Genesis Supersuit. It has some material presets for it, plus four Dynamic Capes, two Cowls and one Hood.
    If you load one of the cowls, go to the Scene tab and do you see the highlighted items shown in the picture below, or just one that says "RIG" at the end. I ask because the .dsa material presets where acting weird, so I loaded it on another computer and all that shows in the scene tab when I load a Cowl is the CowlM5_RIG and there is no Cowl in the viewport. I tried DS 4.0, 4.5 and 4.6 and for some reason only the RIG is showing on this second computer.
    Edit: I added a second picture of the computer that isn't showing the Cowl. All I see is the CowlM5_RIG in the Scene tab and nothing in the viewport. Toggling the Eye icon doesn't make it display.
    720 x 356 - 93K
    980 x 852 - 46K
    Post edited by Lindsey on
  • SimonWMSimonWM Posts: 924
    When this happens that you get invisible dynamic clothes it is because you have an incorrect version of the Dynamic Cloth - Control plugin. Your plugin number must match DAZ Studio's number. If you are running DAZ Studio 4.6.0.18 you must be running Dynamic Cloth Plugin - Control version 1.3.0.18.
    Notice how the last three numbers .0.18 match. As long as your DAZ Studio version number and your Dynamic Cloth plugin number matches you should not have this problem.
