Content Management Question
I installed 4.6 and moved the content from the public folder to my old Daz 4.5 library. I also set the installer to put new content in the old folder as well. I'm getting things to load ok. Did I cause unforseen problems down the road by doing this? I really didn't like the idea of having folders scattered all over my computer, making it more difficult to keep track of and backup ,even if Daz can find everything through the content management system.
Also, just confirming that the default Windows 64-bit installation directory in the install manager is in fact "programs" (accidentally changed it!).
I greatly appreciate your help!
Nope, shouldn't be any issue.
As long as both DIM and your content library are pointing to the same place it'll be fine.
The install manager will install 64 bit software into C:\Program Files and 32 bit apps into C:\Program Files (x86). DIM itself is a 32 bit program so it's installed in C:\Program Files(x86).
Thanks! I was hoping that would be the answer.
