JCM VS WEIGHT MAPS
bloodboybloodboy Posts: 68
I´m new in all this RiggingClothing thing , but i get it done step by step ..
Some how I don´t know when do I need WeightMaps and when JCM ?
Are JCM not better especially if I have Zbrush to make the Moves/Folds etc.. ??
How do you handle it ??
  • Richard HaseltineRichard Haseltine Posts: 111,984
    A JCM is just a morph that is controlled by a joint's rotation, and any morph can move the mesh only along a straight line between the start point and the new point in the morph. A weight-map controls how much of a joint's rotation (or scale) is applied to the mesh, or how much of the bulge effect is applied. So for bending movements you need to use a joint and a weight-map for that joint, a morph won't help; when you want to correct the shape, especially in a limited range of positions, then a morph controlled by the joint is better.
  • bloodboybloodboy Posts: 68
    AH allright , that make sense ... thanks a lot
