Help! Missing Gen 3 Genesis Shapes
paladin_gdipaladin_gdi Posts: 0
edited July 2013 in New Users
Hi
I bought the Gen 3 Iconic Shapes for Genesis pack for Daz. Downloaded everything using the Installer Manager. I think the installation has worked since the other things I bought and downloaded in that Installer Manage run are visible inside Daz.
Well I can't see these Gen 3 shapes anywhere obvious
1) Does anyone know which tab I should look under and what the slider, icon should look like?
2) But if they are plainly not there but Installer Manager thinks it's done its job then what do I do?
I have newly installed Daz4.6 from a clean install, not from an upgrade or anything like that. (Of course before I installed additional content......)
Operating System: Windows 7
Thank you in advance
Post edited by paladin_gdi on
    They should appear as a slider in the shaping tab under 'Actors'.
  • paladin_gdipaladin_gdi Posts: 0
    Hookay....
    Under Actor and Shaping, I see.....
    Basic Female
    Voluptuous
    Basic Male
    Basic Child
    Body Tone
    Body Volume
    Bodybuilder
    Bodybuilder Details
    Emaciated
    Fitness
    Ftiness Details
    Heavy
    Pear Figure
    Pot Bellied
    Thin
    and that's it
    Are the Gen 3 shapes in there or none of those?
    And if there are none of those, please see point 2) in my first post
    Thanks again
  • SloshSlosh Posts: 2,391
    It looks like DIM has installed to the default folder, rather than your DAZ library folder. Easiest thing to do is add the default folder to your directory paths. It's under edit, preferences.
    Hi
    I think we "fixed" it now
    I went to Edit-> Preferences
    Compared what you said with what I saw and concluded it wasnt the temp or cache files folders you were talking about
    Went to Content Library-> Content Directory Manager
    Saw that my preferred folder seemed to be selected folder anyway
    Went to Install Manager and its help-> Changed the destination install folder there even it "didnt want to" as the Help file said DONT DO THIS!!!
    Uninstalled the add-on content and reinstalled to the directory where everything else is.
    Loaded Daz and everything appears to be there under Actor and Shaping
    So yeah thank to everybody.
    But yeah "fixed" instead of fixed as the Help file pretty much said DONT CHANGE THE INSTALL DIRECTORY.
    So fingers crossed. I might be back later if there are any more problems XD
