Genesis 3 Expressions problem
Hi there!
I installed Arabella 7 and Victoria 7
But i can't apply any expressions on them.
For example, I double click the expression in the smart content panel and nothing changed.
The posing tab which controls expressions on the right side also takes no effect
only the expressions in the Genesis 3 Female expressions works
How to solve this problem?
1280 x 720 - 640K
  • MescalinoMescalino Posts: 436
    The expressions in your smart content tab are for teen josie and Gen 3 are you sure you use the ones for Gen 3 (usually they come in 2 different folders).
  • Beat578Beat578 Posts: 191
    And you have to check, that you have selected Genesis in the Scene tab, often if you add clothing, the Focus is switched on the new added cloth instead of the base figure, so the Expressions won't work of course, caus DAZ tries to add them to the Clothing.
    Note that Smart Content sometimes isn't all that smart, and won't show the difference between two sets of content in separate folders.
    Also, those expressions in Smart Content are for applying each pose at full strength, all-or-nothing. The dials for expressions in the Posing pane let you apply a little bit of one, a little bit of the other, and mix them. That's impossible if you use the Smart Content expressions.
