Dformer and morphs
Ok, I know how to use dformer to create, say, an adams apple. I know that I can save the dform as a preset so I can add that to any similar figure. I also know that once added, I spawn a morph and then save that figure with that morph.
But is there a way to save the morph so that it will remain part of m8 (or M7)? Meaning, Is there a way to make that spawned morph a permanent morph that is always there and I just have to dial it in?
  • Richard HaseltineRichard Haseltine Posts: 111,965
    File>Save As>Support Assets>Morph Asset, select the morph, set the Author and product names (these are used to generate folder names in, e.g. /Data/Genesis 8/Male/Morphs), mkae sure - if you isntalled using Connect - that the content directory at the top isn't set to the Connect data directory.
