Sometimes morphs don't load
zug22zug22 Posts: 74
I have a lot of files and for some of them, M4 or V4 morphs don't load when the file is opened. Not all of them, only some. the interface tells me so.
What can I do to fix this?
Is it that my files are too big or something? I have some with seven or eight characters in them - but surely that doesn't matter, right?
Is my content directory getting too big? Should I defrag it?
If the answer is to reinstall those morphs (e.g. morphs++ for V4 etc.) I can do that from DIM but do I need to uninstall them first?
Thanks for your help !
  • SandmanGFXSandmanGFX Posts: 75
    By "files" do you mean scene files?
    With DS3 I used to run into a problem with the Powerloader not loading all of the morphs when trying to load all my products - V4/A4/morphs++/Girl4/etc. I haven't used the Generation4 figures in a while, so I can't remember exactly how, only that there was a workaround. I think it might have had nothing to do with the Powerloader in the end, but instead it was more like the morphs were available, but not showing up in the interface ... not sure tho.
    With Genesis I ran into a similar problem. When dialling in a certain amount of morphs You'll eventually get to the point where the remaining non-diallled morphs will automatically be disabled. This might have something to do with what's happening to you?
  • StratDragonStratDragon Posts: 3,291
    take a look at this bug report and see if this is what you are seeing and if it is please add your comments to it so Daz is aware of who is being affected by this bug
    https://bugs.daz3d.com/view.php?id=48991
    in the mean time you might try to select the figures one-by-one and re-inject the morph packages, this is not a workaround because sometimes it works and sometimes some of the morphs remain broken.
