Genesis Starter Essentials using "The Install Manager"
JRC1334JRC1334 Posts: 71
Can someone please help me to understand how to use the install manager>Genesis Starter Essentials i am using daz4.6 and poserpro2014 and I want to use the dson in poser and in order to that I need Genesis Starter Essentials PoserCF which uses the install manager which is an absolute nightmare I cannot figure this out can someone please give me a step by step (yes i went and read the instructions but they only show you with the daz installers not using the "install manager" please help :)
  • Richard HaseltineRichard Haseltine Posts: 111,972
    You need both the PoserCF files and the core files - the PoserCF doesn't have the geometry and textures. You need to place the files, either using the install manager or by unzipping and moving the folders from the Content folder to the destination folder (note that on Mac, if you use the manual method it's best to use an empty destination folder unless you know how to make the system merge folders). The destination folder is any folder you have told Poser and DS to use as a content directory/external Runtime (in DS, in the Content Library pane, right-click on DAZ Studio Formats and choose Add directory, then do the same for Poser Formats - in Poser click the folder with the + icon at the top-right of the library panel).
    To set a destination folder for the Install Manager, click the gear at top-right to open the preferences dialogue, click the Installation tab, click the + at the bottom-left and select the folder. Click Accept to close the preferences dialogue, then click the Show Details check box on the ready to install tab (or the ready to download tab if you have the install after downloading option on) and pick the folder you want from the drop-down list.
  • JRC1334JRC1334 Posts: 71
    MUCH,MUCH GRATITUDE SIR!!!!! Thank you soooo very much it worked perfectly. I did not even use the install manager. Way easier using the zips. Thank you once again.
