Coverting G3 MALES to G8
I have had pretty good luck transferring a lot of G3F morphs to G8, however now I would like to convert some of the MALE morphs from G3 to G8.  Has anyone done any work on this?  Do you think I could use the same process I'm using for the G3F morphs?
  • y3kmany3kman Posts: 877
    Whatever you're doint to transfer G3F morphs to G8F should also work for the male figures.
  • themidgetthemidget Posts: 287
    I imagine it would be the same for M as for F. Give it a go.
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,984
    It is totally the same
  • Kev914Kev914 Posts: 1,143
    I assume from your other post that you are using Redz's procedure for this. For the G3F to G8F, there was a duf file for loading G8F and G3F into the scene. One of them is hidden. I think if was G3F, Is there anything special about this "scene" that it loads. Can I just load G3M and G8M into a scene and then hide the one? And then just follow the rest of the procedure? Thanks.
