Studio: joint editing on G8 - how to lengthen index finger?
i want to just lengthen the index finger. That's 3 bones. Unfortunately, there are only parameter dials for rotation.
how can I enable the bone's y-scale dial?
I don't want to use a custom morph for something simple like this. Do I have to?
  • Richard HaseltineRichard Haseltine Posts: 111,361
    Try opening the parameter pane's option menu (the lined button in the top corner, or right-click the tab) and enabling Show Hidden Properties. The results may not be satisfactory, however.
  • Try opening the parameter pane's option menu (the lined button in the top corner, or right-click the tab) and enabling Show Hidden Properties. The results may not be satisfactory, however.
    I have hidden properties turned on, but still only see scale option, not y-scale.
    you hve the finger bones selected, you aren't looking at the Pose Controls section on the figure (or hand) node?
  • Thanks for your response Richard. I’m indeed looking at finger node, not the bone itself. Do i need to go into bone editor and scale it there? But then what? Do i then have to adjust rigging or such? Thanks.
