Parenting items to David 3's hand
Does anyone know how to fix the problem with not being able to parent anything to the hand of the David 3 figure? I keep trying to parent a sword to his hand but whenever I change his position, the sword does not move with him.
  • edited December 1969
    I haven't had that problem. What software are you using?
    I am using DAZ 4.6.
  • Richard HaseltineRichard Haseltine Posts: 111,677
    Please post a screenshot showing the parenting in the Scene pane
    Here are the screenshots. Notice how the sword does not move along with his hand, even though it is parented to his hand. Yes, I know it says "right pinky" but it does that even when you select right hand, it still gives you right pinky. There's no way to make it say right hand. It always parents it to his pinky finger. You can select right hand over and over but it will always parent it to his pinky and never move along with his hand. What' s the deal with that?
    1007 x 633 - 195K
    974 x 650 - 368K
    601 x 615 - 166K
  • SassyWenchSassyWench Posts: 602
    First, it is parented to the hand. It just shows up under the the fingers. :)
    As far as it not moving with David.. it looks like you still have the sword highlighted, meaning you're moving the sword, not David. Put the sword back in position and then select David and move him. Betting it will work just fine! wink
    The sword isn't parented to David's hand, it's parented to the "hand" of the Achilles hair, which you then have parented to David (presumably because it's for M3 and so wouldn't conform). Since the figure is parented, not conformed, its pose won't match David's and so the "hand" stays put, and the sword with it.
    Aha! You are right! It was parented to his hair/hand. I fixed it and now it works. THANKS!
