Hexagon (form Silo) Workflow & Terminology
Greetings,
I have been working with Hexagon for a few days, All I can say is wow. Hexagon has all the features i was struggling to get Silo to do.
Since the Key (to every 3D app) is different, I would like to get a good workflow quickly.
Silo to Hexagon Q&A
1) Save custom primitives?
2) Close = Fill?
3) Assign Custom Keys? (nav like Maya)
4) how to "frame" or center Zoom on a selected mesh?
Is there a way to create primitives with custom defaults? (not the default click drag) more like Silo where it is created at the 0,0,0 origin
1x1x1
Thanks!
Post edited by sadicus on
I'll try, tho I don't use Silo:
1 You can modify a primitive (cube, sphere. etc) and save as a .hxn file and use/reuse anytime, but I don't think it can be saved as a pure primitive nor added to the primitive menu list....unless perhaps with re-coding the s/w.
2 Close (not the same as a 2D fill of a closed area to add a material/texture/color) in Hex means to "close" any holes in an object (some or all)...by which Hex adds a surface/face contiguous with the surrounding faces. Select an object that has hole(s), do "close", Hex highlights the openings, click each to close or on panel click on "all"
3 see "prefs" to assign/re-assign keyboard shortcuts; very capable
4 For primitives you can click menu/toolbar and set parameters for position and size(s) and quality/# of faces/points on screen click OR drag object shape from toolbar for default size and set 0,0,0 easily (drag to near center, hold down shift key, release and object center at 0,0,0)
Doug.S
thanks for the info!
2) 2D fill (select edge> 2D fill
4) Primative Drag/Drop = that is cool!
Too bad you can't create custom primatives in the menu.
is there a way to SAVE the custom Palette? It seems to dissapeer when I restart Hexagon.
is there a way to GROUP SELECTIONS? (faces, Edges, etc.)
Silo - Group Selection
Hex2 - Shading Domains
