barbarian fur boots -where's the fur? SOLVED!!
AdemnusAdemnus Posts: 744
edited July 2013 in Daz Studio Discussion
I don't get it. Where's the fur as pictured?
799 x 468 - 247K
Post edited by Ademnus on
    edited July 2013
    Did you edit the materials at all? They come out fine for me.
    /edit
    Check displacement on the mat zone for the fur. It should be at 150 with the min/max being -2/+2.
    500 x 500 - 96K
    500 x 800 - 168K
    Post edited by Lissa_xyz on
  • BlackFeather1973BlackFeather1973 Posts: 739
    1 -> Lighting
    2 -> Render Settings
    Second pic is with standard headlight and my medium qualtiy render settings that i normally use for previews (shading rate 1, pixel samples 8, shadow samples 16).
    926 x 600 - 339K
  • AdemnusAdemnus Posts: 744
    /edit
    odd, i didnt touch the settings.
    1 -> Lighting
    yeah i did one with actual lighting too. Still no fur.
    1906 x 1050 - 294K
    1 -> Lighting
    But definitely an improvement.
    Things you can try : lower the shadow bias from the lights, e.g. 0.2; lower the shading rate in the render settings, e.g. 0.2; raise the shadow samples, 32 should be fine; ...
    It'll take some fiddling to get right, but in the mean time you'll learn how to improve your renders overall.
    Haven,t gotten them as good as i'd like to myself... :-)
  • Richard HaseltineRichard Haseltine Posts: 111,715
    Lower your shading rate - that is crucial for procedurally based displacement-fur.
  • adamr001adamr001 Posts: 1,322
    Yup yup, what he said. Your shading rate is too high.
    hmm ok, will try that
    edited July 2013
    Huzzah! Fur! Thanks to all for the help!
    Ok, this raises some questions. I'm not sure I even had a notion of what shading rate is and does but if I did, whatever it was, I have surely abandoned it.
    1) Explaining like the Professor explains things to Gilligan, wht IS shading rate and quite what does it do?
    2) How does it achieve this furr-ific effect?
    3) what else might it do to things?
    4) Noting the extended render time, will it bog down complex scenes?
    5) will it enhance skin or hair or anything worthwhile? i.e. should I employ lower shading rates regularly?
    1906 x 1050 - 382K
    Shading rate is how finely the geometry is divided and calculated - it's the proportion of a pixel for each micropolygon. So setting it lower chops things more finely, allowing more and thinner hairs for the fur shader and generally making things smoother and sharper. But since it increases the number of calculations, it also slows the render down.
    And if you want a quick and dirty layman's explanation, think of chopping veggies. Sure a quick and dirty rough chop will do the job and not take as long, but it will be clunky and look like crap. Doing a fine dice takes longer, but it comes out looking nice and refined.
    lol
