dForce Classic Long Hair
Can anyone help with this, Black hair renders as Going Grey, other colours also have white in same way. Have tried many ways butmust be missing something. Attached render
Thanks
Pete
786 x 772 - 167K
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Iray or 3Delight?
  • murgatroyd314murgatroyd314 Posts: 1,569
    At a glance, this looks like a glossiness issue.
  • iray, tried the glosines but will try again
  • Iray or 3Delight?
    iRay, so tried again but still didn't work. will get on to the tech. dept
    thanks
  • nicsttnicstt Posts: 11,715
    There is a lot of reflected light.
    Is the light on (headlamp), on the Camera?
    No lights or camera used
  • JMCarriganJMCarrigan Posts: 179
    Other than your problem: How do you like this dForce Hair Model? ( Thanks. I believe the help offered is on the right track. I haven't the model though.)
    Now that I've actually downloaded the hair and had a chance to try it, I've found the answer. It's a Dual Lobe issue. Turning Dual Lobe Specular Weight to zero eliminated the effect completely, though it left the hair color a bit too flat. More subtle adjustments are recommended.
  • Other than your problem: How do you like this dForce Hair Model? ( Thanks. I believe the help offered is on the right track. I haven't the model though.)
    1 - Excellent but will take practice
    2 - by a process of elimination discovered that last night, and yes more subtle adjustments needed, so will give it more practice later,
     just an idea set it to zero then adjust it gradually? but not today. such a lovely day not going to be sitting in front of the comp. all day laugh
    thanks
    Thank You!  I must have something setup that lets me know that someone's answered.
    thanks
    Oh
  • petes imagespetes images Posts: 213
    edited May 2018
    Sorted. Set Dual lobe Reflectivity to Zero as suggested, then adjust Dual Lobe Specular 2 Roughness to the effect required. I found 0.50 to give good results. Tried it with Black, Brown & Red colours
    Pete
    Post edited by petes images on
  • FlortaleFlortale Posts: 611
    edited March 2020
    ... wrong post.
    Post edited by Flortale on
