No Fear, Surprise, Glare, etc. morph dials anymore - SOLVED!?
Somehow I no longer am able to find morph dials for any of the starter essentials face expressions. I search from the parameter tab and nothing comes up. There is not even a Visemes category anymore.
I can still find:
/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLFear.dsf
and
/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/PHMFear.dsf
and all the others.
In fact I can find these .dsf's in multiple places since created some custom morphs. I should also mention that I recently installed Expressive for Genesis if that makes any difference.
I don't know if this relates to another problem I have been having where the Genesis Figure doesn't load on start up, but that problem is a lot older and never seemed to affect anything else.
(the log file is full of warnings like:
WARNING: /src/sdksource/fileinput/dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSurprise.dsf#PHMSurprise?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 5/MCMM5Surprise.dsf but I don't think this explains it as these are all specific to Michael)
Maybe the thing to do here is a full reinstall install....
I hope to confirm,,
when you serch these expression poze controller, did you select head node?
if you simply select root genesis, you can never find
expression poze controlls which assigend for head node.
I can not find any expression, or visemes controll too.
(though if I turned on Show hide property,, Hide PHMs are turned up,
but you never tweak them, without special reason)
About Expression , you need to select head, then use right poze controll.
these are categorized as poze,, then about poze controll,,
you sometimes need to find which node have these controlls.
eg if you select hand you may find hands poze controlls I believe.
Ok now I am 95% sure I tried it with both the head node and full figure selected and got no result. Since then, I consolidated the CMS database and rescanned my hard drive for content. Now it looks like everything works. So maybe "Id10t" error and maybe this required a rescan but Problem solved in either case.
