MRL Amara Braids .. Oddity
Hello,
I find myself needing to use the MRL Amara Braids for Genesis 3 and 8 Female(s) on a G8M. It comes in okay and fits great but once there, all the morphs that are associated with the hair are gone. Is there something I'm doing wrong?
No other hair really looks right on this character but I do need to be able to utilize the movement morphs.
Any thoughts?
  • SimonJMSimonJM Posts: 6,100
    I've just loaded AMara hair onto a G8F and all looks fine, with quite a few morphs/poe controls available and working.  If I load the G3F version of the hair I still see the morphs/poses, but they do not work.  So I'd suspect you are laodign the wrong version.
  • vwranglervwrangler Posts: 5,044
    Wait ... on a Genesis 8 MALE? In that case, if you're allowing Autofit to invoke, what's likely happening is that the process is destroying the bones that the morphs need to work. You'll need to bring that into the scene, cancel Autofit if it invokes, and then parent it to the head. Use scaling and/or adjustment morphs (if any) to get it to fit properly on the head. Do not, under any circumstances, use "Fit to", because that will invoke Autofit.
    Ooops, missed the G8M part .. ;)
  • ArtsyDragonArtsyDragon Posts: 682
    Thank you for that @vwrangler. I couldn't make the hair fit properly so I had to opt for plan B. Took me a while to figure out plan B but I think I got it. I'll work on it another time and see if I can make it fit later.
    @SimonJM, I figured you'd missed that it was the male I was trying to use. Thank you for taking the time to test and respond though. I appreciate it.
