Body Trans/Rotation to Hip
to Make use-any-where-poses from a set of non-use-anywhere-poses . Is there some type of mathematical formala to use for this. I understand transfering Body Translation to HIp would be simple addition and subtraction but what about Rotation? Hopefully I was about to explain myself well enough.
Post edited by TimingisEverything on
If I am understanding correctly, you would like to use pose sets that move the character around, but make them not move and rotate, only pose?
Yes that is correct. but I am also using poses that have two characters interacting, so I couldn't simply lock the translations/rotations. I probably should have added that part in my main post
DS or Poser?
If you are using DS then you could Group the 2 characters, then move/rotate the group back to the Zero point, or anywhere else you wanted. Then if you want to save the poses UnGroup them and save the poses.
I don't use Poser, so I don't know if you can group items with it, but it should work as well if you can.
