How to restore headlight?
pauljacob11pauljacob11 Posts: 203
After choosing a spotlight and later deleting it, the figure became a silhouette -- completely dark. How do I restore the headlight? Is there an on/off keyboard shortcut?
  • SzarkSzark Posts: 10,634
    CTRL (CMD for MAC) + L should do the trick.
  • Richard HaseltineRichard Haseltine Posts: 111,332
    edited June 2013
    Are you sure there isn't another light of some kind in the scene? Open the Scene pane option menu (click the menu button in the top corner, or right-click the tab) and then Select>Select All Lights.
    edited June 2013
    Yes generally the headlight normally comes on automatically when the last light in the scene is deleted. If unsure you can always use the "Select All Lights" command from the Scene Pane's Options Box.
    Post edited by Szark on
  • pauljacob11pauljacob11 Posts: 203
    Thank you Szark for Cntrl-L, that's really handy shortcut to have, and thank you Mr. Haseltine for your reply. After reading it I realized that I had not deleted the light, just turned it off. When I did delete the light, the headlight shone bright. Merritt in his light presets tut has a light bulb icon on his workspace. What must I do to conjure that icon onto my workspace? I'm using the self-serve workspace. TIA for your help. Have a great weekend gents.
    Ok to add the icon to a tool bar
    Window > Workspace > Customise or F3.
    1 Find the Preview light Icon
    2 select Toolbars
    3 Drag the Preview light in to the heading of the toolbar in this case Viewport Tools.
    4 The Preview light should now appear in the list
    5 It should now be in your tool bar.
    1324 x 985 - 565K
    Thank you Szark, really appreciate your detailed guidance. I hope to learn much from your lighting tutorials.
    You are welcome and hope you find them helpful.
