Aven for Genesis
mikecrea34mikecrea34 Posts: 59
So I downloaded this character, and I see the character materials but not the character morphs.
I manually downloaded and the character morphs are in the character folder but I don't know what folder to extract them into.
Aven.zip\Content\data\DAZ 3D\Genesis\Base\Morphs\3D Universe\Aven
And that's where the character morphs are, any ideas?
It does say on the product page:
  • This product must be installed to the same location as Genesis.
I've tried moving the file from the data folder to different spots, but no luck
Post edited by mikecrea34 on
  • Richard HaseltineRichard Haseltine Posts: 111,831
    The data folder from the zip needs to emrge with the existing data folder in one of your content directories.
  • Do you mean the data folder for Genesis itself?
    I have documents, then Daz 3D, then Studio, then My Daz Connect Library, then inside that is Content and Data
    Do i move it to that Data folder?
    I'm still kinda lost
    The My daz Connect library is, unless you have changed the path, used only by content installed by Connect (that is, from inside Daz Studio). No content directory should have a folder named Content inside it.
  • Well in case I messed something up i reset my computer and reinstalled everything from scratch.
    Still having the same problem, I can see Aven's character textures, but I don't have the character morphs, but I know the morphs are in the download, i just don't know where they went, or where to move them in to.
    Any help?
    I don't have Aven to test, if no one else chips in you may need to open a Technical Support ticket.
  • GoneGone Posts: 833
    Aven only has one morph dial that should be under Parameters->Actor->Female->Real World. There is no Smart Content preset for the morph.
  • Oh okay, that worked.
    Awesome, thanks very much.
  • WandWWandW Posts: 2,907
    Yes, there is not any entry for Aven in the Character library.  I loaded Genesis, dialed in the morph, applied the textures and saved it to the Character Library...
