Creating a .x file
wizard1200wizard1200 Posts: 240
edited June 2013 in The Commons
Is it possible to create a .x file of a model with DAZ Studio 4.6 Pro?
Post edited by wizard1200 on
  • Richard HaseltineRichard Haseltine Posts: 111,972
    Not directly - you would need to export in a format DS does support, then open that in another application and save as .x. Remember that if you are wanting to share a game created DAZ 3D content you will need to buy one or more Game Developer Licenses, and limit the content used to that from vendors covered by the license(s).
  • wizard1200wizard1200 Posts: 240
    Thank you very much for the reply. What kind of application would you suggest to convert the file?
    As I recall, Carrara will write to .x - though I haven't had occasion to test that.
  • Dream CutterDream Cutter Posts: 1,224
    The most versatile and complete 3d animated mesh conversion software is (IMO) Ultimate Unwrap 3D. Its way more than just UV unwrapping. You can convert to almost any animated 3d mesh format and even adjust animations, rigging and joint weighting for comparability.
    Other perhaps less versatile but "slicker" mesh conversion options include "DeepMesh 3d", and "FragMosoft". And Blender with plugin.
    Thank you very much for the help. I guess converting the file with Bryce should be possible, too, right?
    edited July 2013
    Bryce will import them
    Can add no more than that, as it is something I have never tried.
    Post edited by Chohole on
  • FSMCDesignsFSMCDesigns Posts: 12,858
    Agreed, but Ultimate Unwrap 3D is $70, you can also use LithUnwrap which is free for the direct X format conversion.
  • bighbigh Posts: 8,147
    yes you could use Bryce - works good
    easy to do using the bridge to send from DS to Bryce and save as .x file
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,797
    I did manage to save Sonemasons streets of Asia 2 as an .x file from Carrara and open it in MikuMikuDance as a prop
    so know it is possible.
