What does this error message mean?
MydsMyds Posts: 106
2018-04-21 17:02:09.681 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
​Whatever it is, it keeps crashing the program to desktop.
​It says cloud.  To my knowledge, it shouldn't even be running anything in the cloud.  I think all my materials are installed locally.
Post edited by Myds on
  • Until someone smart comes along, I'll take a guess: I got a similar error, but it crashed a render not all of DS. I tried working offline and the render completed.
  • MydsMyds Posts: 106
    Oh, hey, there's a working offline option?  I'll go look for that.  Good call.  It's crashing too much with this recently.
  • Richard HaseltineRichard Haseltine Posts: 108,720
    Is DS connected (atomatically or by using the menu command? In any event, the "cloud" messages relate to interaction with Connect whether or not you are on line. What security software are you using?
    edited April 2018
    I have Norton Internet Security.  Alas, working offline didn't solve the problem.  Toward the beginning of the render, the screen blacks out for a moment, then the CPU takes over again.  No good reason this time, the scene isn't very big.  Whether I let it render with the CPU or cancel, I get a CTD.
    Geometry Consumption 116 MB, Materials 718 KB, and I have two GPUs of 8 GB each.
    I'm seeing if this works.  I went to GEForce Experience, and killed the option for "In Game Overlay."  Based on the success Ia guy seemed to have her by turning off Nvidia Share, which doesn't seem to be a thing Ic an find anymore.  I assume in-game-overlay replaced it.
    https://forum.nvidia-arc.com/showthread.php?15826-1080-ti-!!!Need-Help!!!-IRAY-does-not-work-in-the-Daz3D-program
    edited April 2018
    Nope, still defaults back to CPU then crashes at the beginning of the render.  These are two Non-SLI GTX 1070's.  Running driver 391.35 installed by GEForce Experience.
    2018-04-22 15:29:02.173 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating geometry.
    2018-04-22 15:29:02.272 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using built-in ray tracing (1.0.0).
    2018-04-22 15:29:02.272 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing scene graph.
    2018-04-22 15:29:02.272 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing geometry.
    2018-04-22 15:29:04.062 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Geometry import (1 object with 4280k triangles, 1 instance yielding 4280k triangles) took 1.790206
    2018-04-22 15:29:04.062 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating materials.
    2018-04-22 15:29:04.110 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_TD3_AZone__Terrain_114f_612' uses MDL JIT compilation.
    2018-04-22 15:29:04.110 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_TD3_BZone__Terrain_118c_695' uses MDL JIT compilation.
    2018-04-22 15:29:04.116 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : found 523 textures, 2 lambdas (1 unique)
    2018-04-22 15:29:04.132 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Emitter geometry import (15 light sources with 38242 triangles, 1 instance) took 0.00s
    2018-04-22 15:29:04.132 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating environment.
    2018-04-22 15:29:05.814 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lens.
    2018-04-22 15:29:05.814 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
    2018-04-22 15:29:05.818 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
    2018-04-22 15:29:05.819 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
    2018-04-22 15:29:05.819 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
    2018-04-22 15:29:05.829 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Allocating 1 layer frame buffer
    2018-04-22 15:29:05.834 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
    2018-04-22 15:29:05.838 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Initializing local rendering.
    2018-04-22 15:29:05.890 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 2 device(s):
    2018-04-22 15:29:05.890 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info :  CUDA device 0 (GeForce GTX 1070)
    2018-04-22 15:29:05.890 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info :  CUDA device 1 (GeForce GTX 1070)
    2018-04-22 15:29:05.890 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
    2018-04-22 15:29:05.894 Iray VERBOSE - module:category(IRAY:RENDER):   1.7   IRAY   rend progr: CUDA device 0 (GeForce GTX 1070): Processing scene...
    2018-04-22 15:29:05.895 Iray VERBOSE - module:category(IRAY:RENDER):   1.6   IRAY   rend progr: CUDA device 1 (GeForce GTX 1070): Processing scene...
    2018-04-22 15:29:08.993 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.2   IRAY   rend warn : RTKernel: please check the input geometry (degenerated/inefficient RT hierarchy)
    2018-04-22 15:29:09.035 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Geometry memory consumption: 116.79 MiB (device 0), 0 B (host)
    2018-04-22 15:29:09.040 Iray VERBOSE - module:category(IRAY:RENDER):   1.2   IRAY   rend stat : Geometry memory consumption: 116.79 MiB (device 1), 0 B (host)
    2018-04-22 15:29:37.932 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Texture memory consumption: 3.3661 GiB (device 0)
    2018-04-22 15:29:37.932 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : Initializing light hierarchy.
    2018-04-22 15:29:37.933 Iray VERBOSE - module:category(IRAY:RENDER):   1.2   IRAY   rend stat : Texture memory consumption: 3.3661 GiB (device 1)
    2018-04-22 15:29:38.336 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : Light hierarchy initialization took 0.40s
    2018-04-22 15:29:38.340 Iray VERBOSE - module:category(IRAY:RENDER):   1.2   IRAY   rend stat : Lights memory consumption: 6.42556 MiB (device 1)
    2018-04-22 15:29:38.340 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Lights memory consumption: 6.42556 MiB (device 0)
    2018-04-22 15:29:38.477 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Material measurement memory consumption: 0 B (GPU)
    2018-04-22 15:29:38.529 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Materials memory consumption: 718.402 KiB (GPU)
    2018-04-22 15:29:38.529 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : PTX code (1.66 KiB) for sm61 generated in 0.0514s
    2018-04-22 15:29:38.530 Iray VERBOSE - module:category(IRAY:RENDER):   1.2   IRAY   rend stat : PTX code (1.66 KiB) for sm61 generated in 1.53e-006s
    2018-04-22 15:29:39.532 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : JIT-linking wavefront kernel in 0.055s
    2018-04-22 15:29:39.549 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : JIT-linking wavefront kernel in 0.053s
    2018-04-22 15:29:39.564 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : JIT-linking mega kernel in 0.028s
    2018-04-22 15:29:39.564 Iray INFO - module:category(IRAY:RENDER):   1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 33.669s
    2018-04-22 15:29:39.569 Iray INFO - module:category(IRAY:RENDER):   1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 20.2893 MiB for frame buffer
    2018-04-22 15:29:39.571 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : JIT-linking mega kernel in 0.021s
    2018-04-22 15:29:39.571 Iray INFO - module:category(IRAY:RENDER):   1.6   IRAY   rend info : CUDA device 1 (GeForce GTX 1070): Scene processed in 33.676s
    2018-04-22 15:29:39.576 Iray INFO - module:category(IRAY:RENDER):   1.6   IRAY   rend info : CUDA device 1 (GeForce GTX 1070): Allocated 20.2893 MiB for frame buffer
    2018-04-22 15:29:39.625 Iray INFO - module:category(IRAY:RENDER):   1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.65625 GiB of work space (2048k active samples in 0.054s)
    2018-04-22 15:29:39.625 Iray INFO - module:category(IRAY:RENDER):   1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
    2018-04-22 15:29:39.633 Iray INFO - module:category(IRAY:RENDER):   1.6   IRAY   rend info : CUDA device 1 (GeForce GTX 1070): Allocated 1.65625 GiB of work space (2048k active samples in 0.057s)
    2018-04-22 15:29:41.764 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): Kernel [1] failed after 2.129s
    2018-04-22 15:29:41.764 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 1 (GeForce GTX 1070): Kernel [1] failed after 2.124s
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while launching CUDA renderer in core_renderer_wf.cpp:807)
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 1 (GeForce GTX 1070): unspecified launch failure (while launching CUDA renderer in core_renderer_wf.cpp:807)
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): Failed to launch renderer
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 1 (GeForce GTX 1070): Failed to launch renderer
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.7   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): Device failed while rendering
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 1 (GeForce GTX 1070): Device failed while rendering
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.7   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while initializing memory buffer)
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.6   IRAY   rend warn : All available GPUs failed.
    2018-04-22 15:29:41.765 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.7   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-04-22 15:29:41.766 Iray INFO - module:category(IRAY:RENDER):   1.6   IRAY   rend info : Falling back to CPU rendering.
    2018-04-22 15:29:41.766 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.7   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-04-22 15:29:41.766 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 1 (GeForce GTX 1070): unspecified launch failure (while initializing memory buffer)
    2018-04-22 15:29:41.766 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: All workers failed: aborting render
    2018-04-22 15:29:41.766 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 1 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-04-22 15:29:41.767 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.7   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-04-22 15:29:41.767 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 1 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-04-22 15:29:41.767 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-04-22 15:29:41.768 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-04-22 15:29:41.768 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 1 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-04-22 15:29:41.768 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CPU: using 8 cores for rendering
    2018-04-22 15:29:41.768 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 1 device(s):
    2018-04-22 15:29:41.768 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
    2018-04-22 15:29:41.768 Iray VERBOSE - module:category(IRAY:RENDER):   1.6   IRAY   rend progr: CPU: Processing scene...
    Same image, I deleted the "Atmosphere" from Terradome, and it rendered all on GPU's, blazing fast.
    sounds like a scene specific issue
    Yes, I've been having a few of those lately, it comes up every 2-3 scenes.  I'm hoping to find the common denominator.
  • Kyan001Kyan001 Posts: 75
    edited April 2019
    That error has disappeared from last beta update, but a new one came out "302".
    2019-04-21 07:11:24.273 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(302):
    I'm starting to hate the date I chosen Daz between it and Poser.
    Post edited by Kyan001 on
  • DMindsDMinds Posts: 48
    im getting this error o :(
  • im also getting this error how do i fix it :(((?
    and the crash?
  • FirePro9FirePro9 Posts: 456
    edited February 2020
    When running multiple GPU's, check Rendering Settings | Advanced (Iray) and make sure that Interactive Devices is set to use only one GPU (particularly if the Draw Setting | Draw Mode is set to Interactive).  See this thread for more info:  https://www.daz3d.com/forums/discussion/365326/multi-gpu-keeps-crashing#1
    BTW, the error log above includes the following:
    "2018-04-22 15:29:39.625 Iray INFO - module:category(IRAY:RENDER):   1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)", ....then everything after that line fails.
    Post edited by FirePro9 on
  • dzcloudtasknotifier.cpp(178): recv failed errno=10054
