Iray settings to dial back for workspace test renders?
Hello -
Would anyone care to share what Iray settings they dial back in order to do "quickie" test renders in the workspace to evaluate lighting, etc.? I'm just looking to save a little time in setting up for the final render.
Thank you!
  • Griffin AvidGriffin Avid Posts: 3,882
    Aside from using the iray preview, there's this product that has Many iray render presets. The DRAFT one is probably the one you're looking for.
    https://www.daz3d.com/render-studio-iray
    * The iray preview (mode) is a look at what your current render settings should give you.
    There is also this product
    https://www.daz3d.com/render-throttle-for-iray
    That lightens the burden and gives a few lo-res settings for the viewport- so if the iray preview mode is too slow to ...preview, this should make it possible to use on low end machines.
    I use the first one, Render Studio Iray all the time to keep my render quality consistent (I reset after using Vendor-sourced render settings and computer crashes)
    And used the second, Render Throttle (which worked well-enough to recommend) until I grabbed a beefier Video card and PC. Still, I only use preview mode to make sure the backdrop (an iray skydome) or lightning works as expected.
    A third option to help is Scene Optimizer which also lightens the PC load and makes scenes...RAM-digestible. lol
  • Aside from using the iray preview, there's this product that has Many iray render presets. The DRAFT one is probably the one you're looking for.
    Thanks very much indeed. I might look into these if I decide to keep using Iray. But for now, I'm just looking to minimize the time it takes to see a rough draft.
