Interactive Lessons - Feedback
As a new user, I appreciate the included interactive lessons. However, the auto-fit lessons are: (1) inaccurate and (2) don't work.
(1) The Using Auto-Fit - Genesis to Genesis Female (and Genesis to Genesis Male), when following the walk through exactly, do not actually autofit the clothing to the model/actor. I do know to drag the item over the actor, wait for the pop-up and use the appropriate dropdowns and the garment fits. However, as a tutorial goes - it doesn't provide the instruction necessary for the user.
(2) The Using Auto-Fit - M4 to G2M and Using Auto-Fit - V4 to G2F bring up a message box stating: "File Not Found." 1 file required by the interactive lesson cannot be found. Check taht the content is installed correctly and try again. The missing file is provided by the following product: The products are installed, M4 and V4 are listed and load if selected from the content panes. I did try uninstalling and reinstalling the Using Autofit lessons, with no change in the situation.
Which product does it say is missing?
Attached is the exact message.
And you have https://www.daz3d.com/michael-4-for-genesis-2-male and it is installed, via Install Manager or Connect?
