Cypress, experiment
Retro LadRetro Lad Posts: 472
edited April 2018 in Carrara Discussion
My "tumbleweed"post was a success, so now the new challenge is making decent looking Cypress Trees. I was going to buy, whenever it was on sale, Predatron's Pred Pack - Cypress Trees, but the item seems to have been pulled. What happened.
Well anyway, I posted a Cypress Tree making question in the Bryce Forum a year ago or so. One Brycer came up with a pretty good Bryce Cypress Tree, but again Carrara has better features in the plant making department.
I made a Bryce Cypress Tree but it in was "stinko".
I  attached some pictures I found of Cypress Tree from the Web.
1600 x 1600 - 734K
500 x 650 - 110K
Post edited by Retro Lad on
    edited April 2018
    That's not an easy one to do. I gave it a shot though. laugh
    My model is attached to this post as a zip. Anyone is welcome to use it for any purpose you could normally use Carrara generated trees for.
    You might want to play around some more with the branch lengths and the curve for the custom tree shape. I had forgotten that custom tree shape curve setting was even in there until I saw it in Selina's tumbleweed in the other thread, but it's super useful for trying to get shapes like this. For the best result you will probably need to model the cypress tree leaves yourself - I used the pine needle group that comes in the Carrara content for mine.
    Quick scene I threw together using the tree model above:
    960 x 1280 - 64K
    zip
    zip
    MDOCypressTree002.zip
    776K
    1280 x 960 - 177K
    Post edited by MarkIsSleepy on
  • DiomedeDiomede Posts: 15,464
    edited April 2018
    Great job, Mark.
    At one point, I spent a good bit of time exploring the Carrara plant editor.  Of course, I've forgtten most of it since then.  However, people might be interested in a series of posts that begin at this link.
    https://www.daz3d.com/forums/discussion/comment/2413676/#Comment_2413676
    One tip that people offered me that is pretty important to anyone intending to model and render their own trees is that the UV map for the trunks and branches should be tiled with a 3:1 ratio  (I think).  In other words, if you take your own pictures of a trunk, create your own square tileable texture, and you apply it flat without correction, it will be distorted 3:1 (I think).
    Post edited by Diomede on
    Diomede said:
    Great job, Mark.
    Interesting reading - I know I've poked my head into that thread in the past and found lots of interesting stuff, but I somehow missed your tree experiments. Wish I'd read your notes first, because I didn't start with the tree shape and ended up having to redo a bunch of settings.
    Thanks for doing all that work and posting your results!
    I forgot so much!
    I even had a post specifically on the tree shape editor that Selina used for the tumbleweed.  I'm trying not to despair.  frown
    1270 x 970 - 127K
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Diomede said:
    I forgot so much!
    Thanks, I feel better.smiley
    Diomede said:
    I forgot so much!
    LOL - at least I can help spread joy indirectly.
    huuh??
    i ooked up the Predatron Silver Birch Trees  from my product lib and there is no link to store page ???
    Mistara said:
    huuh??
    Yeah - I have about a dozen of @Predatron's tree products and none of them have store pages anymore. Maybe he(?) pulled them for some reason?
  • Bunyip02Bunyip02 Posts: 9,345
    MDO2010 said:
    Mistara said:
    huuh??
    Same here, flower & tree products.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,689
    It is odd and we cannot speculate the reason either, thank god Carrara has its own tree modeller so we are ok while the DAZ studio users weep as we cannot share our Carrara trees with them either unless they actually buy Carrara and export full detailed mesh.yes
    We should create and share botanical forests of Carrara format trees, make a Carrara tree repository enlightened
  • Retro LadRetro Lad Posts: 472
    Thanks for your helpful posts.
    Don't despair too much Diomede, I attempted to make a tumbleweed today from scratch and ended up giving up in an hour, or was it an hour and a half. I bought the pro version of Carrara 8.5 years ago and just loaded it up once and a while, to learn the basics. So it's work, work, work now, until the Carrara control options become second nature to me.
    MDO2010,
    Your Cypress Tree model looks like a great start to me, and thanks for the zip file and your demonstration scene of rows of Cypress Trees.
    edited April 2018
    another thing you can do for any tree is drag a plane primitive into the leaf browser
    then add that as a leaf to a tree and use a alpha image like a png of any leaf or flower rotating or flipping as needed
    800 x 1139 - 594K
    I will say though that actual geometry (limit the polygons) will cut down on render times as opposed to the billboard method Wendy described. It takes a lot of light calculations, and if you used soft shadows it will slow to a crawl. Shadow buffers won't work as they don't do transparency.
    Octane Render laugh
    I did do that with the native engine though
    I remember woodland renders taking a week or more when I played with transmapped leaves. Replacing them with modelled leaves cut the render time to mere hours! (although then you're faced with the 2 million poly tree!)
    edited April 2018
    There is a free tree program called Arboro.  It can export as obj.  You need Java.
    http://arbaro.sourceforge.net/
    and here is a youtube explaining usage of Arboro.
    https://youtu.be/cx_Lv06Zbtw
    edited April 2018
    pinecones?heart or berries?
    somehow pinecones cansometimes  smell like cinnamonnee
     heard the trees can have 2 types of leaves on em nowadays.
    shoe tree?
    Post edited by Mistara on
    shoe tree?
    yes I added 3 of my planes to my tree and used 3 different png images with alpha transparency
    objs can be dragged into the leaf browser too but can only have one shading domain
    edited May 2018
    I tried making berry canes after seeing Martin Frosts ones in store,
    best buy those,
    mine are horrendously high poly obj as leaving them as leaves and plants crashed Carrara or made the UI crack up
    1920 x 1080 - 92K
    1920 x 1080 - 80K
    1920 x 1080 - 54K
    edited May 2018
    I struggled to even upload a single berry for your dessert
    https://www.daz3d.com/forums/uploads/FileUpload/65/fcee0940a3cd89bd250d862ac1724d.zip
    3 texture choices, you may need to flip them
    zip
    zip
    blackberry.zip
    5M
    2048 x 2048 - 815K
    2048 x 2048 - 840K
    2048 x 2048 - 778K
    and a video of my canes
  • 3DAGE3DAGE Posts: 3,321
    edited May 2018
    Nice clip wendy,. ;)
    you got me playin again
    Try this little berry...
    https://www.dropbox.com/s/hgeedy1felvjzdh/Berry build.zip?dl=0
    there's a Low and higher version ,. but i prefer the low,. the UVs layout is better ,. ..messing around and experimentaling again.
    the texture is just a simple gradient shader,. but you could use whaterver maps you have, ,.. :)
    >>> added a couple if texture maps to the zip
    to make this I used the surface replicator to places the hemisphere (berry bit's) on a basic husk,. then made those bit's real instances,. and deleted the replicator.
    Export that Group (berry and bit's) out as an OBJ,. then imported it back into carrara to UV and texture,
    hope it helps :)
    640 x 480 - 11K
    Post edited by 3DAGE on
    edited May 2018
    my feeble attempt to make a blackberry bush
    edited to add the correct carrara image.
    1280 x 720 - 479K
    1280 x 720 - 107K
    If it is just for Carrara. I would just make the leaf one or two polys and if they are N-gons, so be it. Then use the leaves in the plant editor. Since the leaves are then basically replicated, the resource hit is pretty low.
    lovely berries 3Dage, will be on my PC tomorrow and grab your fruit, mine was actually a bunch of replicated spheres too originally which I created a unified skin in zbrush for and zremeshed so actually pretty low poly
