Mystical glowing pool.
Hey guys,
I want to know if there is a way to make a pool of water look like it is glowing from underneath the water differrent colors.
Thanks
  • You could try creating lights and lowering them in the water so they glow into the area.  If you want multiple different colors create as many lights as needed and set each one to the desired color.  This is one purple light in the middle under the water.
    1000 x 750 - 389K
  • VladricVladric Posts: 6
    Thanks, which light are you using (spot light, linear point, or just point light)?
  • MarcCCTxMarcCCTx Posts: 947
    Could you use a ghost light stuck in the pond to do this? https://www.daz3d.com/iray-ghost-light-kit
  • dawnbladedawnblade Posts: 1,723
    edited April 2018
    Check out the promo of the backlit pool using Rim Light Rig Iray. The water fountain promo is also cool too using 3 light rigs. I have this product and I really like it!
    He also made it for 3Delight initially here.
    Post edited by dawnblade on
    Thanks, MarcCCTx and dawnblade. I real like Rim Light Rig lray, I think that is what I will use.
    Maybe just using a primitive plane underwater with a uber Iray light shader can do the job?
    Depends a bit on the effect that is supposed to be achieved I guess...
