AUTOMORPH TRHOUGH TRANSFER
bloodboybloodboy Posts: 68
Hi I work a lot with Genesis for my Illustrations
In some cases I take something from M4 or V4 or I model mysel ..
But almost when I transfer some kind of Automorph in the new RiggedClothing ..
How can I avoid that ? Because I can use my OwnMorphs to Fit Genesis and don´t need these Automorphs ??
Are there a clickable button or do I have to do more to abvoid the AutoMorphs ??
greets Tobias
  • Richard HaseltineRichard Haseltine Posts: 112,003
    If you create your own morph and give it the same name as the figure's morph (name, not label - you can get that by clicking the gear on the slide and going to Parameter Settings) then DS will not generate a morph of its own; if there is already a morph generated, you can delete it from Edit>Figure>Clear Generated Morphs or you can overwrite it in Morph Loader Pro by setting Overwrite existing to Deltas only. You can also stop DS from generating a morph in the first place by setting AutoFollow to off in the Parameter settings on the base figure, but that will affect everything.
  • bloodboybloodboy Posts: 68
    Thanks a lot .. I think this will help ..
    edited June 2013
    the problem seems solved,, but
    Sorry,, May I ask about "Edit>Figure>Clear Generated Morphs ",,
    Does the Action really work with triax-weight figures?
    Because I have often tried the "Clear Generated Morphs"
    for fitted figure (Hair ,Clothing ) , I have never succeed to remove Generated Morphs.
    the Hair keep the hide generated property, and can not remove the value.
    I simply use select the Hari or clothing, then Edit>figure>Clear generated Morphs,,
    but it seems not work.
    my way is wrong?
    even though I wear off the Hair from genesis,, and try same step,
    there still keep the property,,
    So that I wan to know,, How to use the Action @@;
    I know About weight map tool option, there seems same clear option.
    I though it may remove the effect of JCM or MCM which geneated to the clothings,
    when I color weight on figure rig which fit to genesis, and check with rotating genesis rig,,
    But I seldom use or try the option,,
    Becaues I can not grab it well how it work or not,,,
    Post edited by kitakoredaz on
    Are the morphs still in effect? If so I suspect they get regenerated, though I haven't tested this.
    Thank you. Now,, I understand clear.
    DS auto generated the morph again immediately .
    As you said,, the Action need to check off the "Auto Follow" of genesis morph first.
    After that remove generated morph as the hair, it work without problem.
    And I need to keep fitting the figure (hair) to genesis. When I take out hair from genesis, (fit to none)
    then try to remove generated morph, it can not work. the hidden property are still generated the figure,
    Then,, even though I already set off the morph of genesis as No Auto follow,
    When I fit the hair to genesis Again,, the recorded value immediately return. ^^;
    Where exactly can I found the Paramater Auto Follow ?
    In the parameter's setting - click the gear icon at the end of the slider.
    all controller has Parameter Setting tool. (in shaping tab, in pozing tab, in parameter)
    you can access it by right top small gear of each parameter.click the gear,, it will turn up.
    then there shoul be option, Auto Follow.
    (if you check off, the parameter not auto generated to clothings which fit to the figure)
    887 x 633 - 102K
    I understand ,thanks a Lot !!
