Lighting Help
I am trying to light portraits and full length figures without a lot of success. I have watched the youtube videos on 3 point lighting but I never seem to get the same results as others manage.
Are there any advanced tutorials on lighting figures I should watch? Are there any tutorials which cover the lighting types other than spotlights available in Daz? Should I be looking at a thrid part lighting package and if so which one?
  • WolfStarWolfStar Posts: 84
    Which renderer are you using? 3Delight or Iray?
  • I found this product pretty good for portraits
    https://www.daz3d.com/boss-pro-light-set-for-portraits-promos
    I haven't watched this yet, but the tutorials from dreamlight are usually pretty good https://www.daz3d.com/conquer-3d-now-vol-2--portrait
  • BradCarstenBradCarsten Posts: 856
    edited April 2018
    What is different about the results?
    For figures have you got a good skin shader or texture?
    I like to use primitive planes to light as it gives softer shadows.
    - create > new primitive > plane
    - angle it towards your figure.
    - go into surfaces tab and select the primitive
    - in your Content library tab > Shader presets > iray > Daz Uber, Add the uber base  shader. then add emissive.
    - go into surfaces tab and make sure the lumens are quite high- 500,000 etc.
    Post edited by BradCarsten on
