Problems with morph after reinstall Daz studio
I have been using Daz studio 4.10 for a while with no problem. Since it is initially on my small solid state C drive, so I decided to uninstall and reinstall on my D drive to be able to expand the library. The programs and contents are downloaded/installed in D://Program Files vis install manager plus I deleted the recommended path from install manager to avoid the confusion. The contents show up, but I cannot apply any morph (face, body, etc.) to the figures. The character can be loaded only texture but no morph of the character. I had no such a problems before when the program was on the C drive and the contents were installed follow the recommend path in the install manager. Something must go wrong with direcory in my D drive. Please advise, your help is very much appreciated.
There are two technologies associated with DAZ Studio that must be made aware of the location of your content library if it is not in the default location. One is DIM (DAZ Install Manager), which is responsible for downloading and keeping track of the DAZ content that you have, and the other is the CMS (Content Management Service) that DAZ Studio uses to display and access your content. It sounds as though you have made the necessary changes to the DIM install path (although you only say that you deleted it - presumably you replaced it with the new install path?).
The CMS uses the PostgreSQL database to record the contents of your library. Did you Re-install it as well as DAZ Studio? Is the CMS running when you open DAZ Studio?
You can check if the CMS is running (make certain DAZ Studio is not running when doing this) by opening Windows Task Manager and selecting the Services tab. Look down the list until you find "DAZ Content Management Service". Under the Status column it should show "running". If it is not, right-click on status and choose start. (Note: the CMS is not required to use DAZ Studio, but you must use the Content Library tab to access your content rather than the Smart Content tab if it isn't used).
Have you changed the locations of your content for DAZ Studio Formats and Poser Formats (you need to specify the paths for both of these as the texture maps and sometimes other necessary files are stored under the Poser runtime folders) to indicate the new paths?
The Content Directory Manager (part of CMS) can be found under Edit >Preferences and by selecting the Content Library tab in the popup window. You will see a button for Content Directory Manager at the bottom - click on that and a popup window will show where you enter the paths to your content files, as mentioned earlier, under Current Directories. Expand each of the DAZ Studio Formats and Poser Formats items to reveal the current paths, and ensure that they are correct. If not enter your new paths in each. The two entries should be the same unless you are using more than one content library.
Thank you for your advice. I can solve all the problems in a minute plus found out about product update as well. Thanks a lot.
