The lighting shadow doesn't give change when render mode
Hi guys, nice to meet you
i'm new in Daz3d software, and my first starter pack is michael 8 bundle pack and also some other props
I'm trying to give some lighting effect to my character, but when i change the mode into i ray mode, the shadow/the ray light doesn't change at all
i've been watching some of lighting tutorials on youtube and all my render setting is at the default setting, but it doesn't give me any solution with this small problem.
2560 x 1440 - 949K
  • Richard HaseltineRichard Haseltine Posts: 111,306
    If you are using the default settings then the scene is lit by the HDR Ruins environment map, which is probably swamping any local lights. You may need to set the Environment Mode in Render Settings to Scene Only, and then probably adjust the Tone Mapping settings to be able to see anything.
    edited April 2018
    Check to see if the camera headlamp is on (Parameters>Camera). This will also overwhelm some local lighting. It is generally advisable to set the headlamp to OFF. Alos in Render Settings> General, set Auto Headlamp to Never.
    If your scene is dark in the viewport, use CTRL L to toggle preview lights.
    Post edited by fastbike1 on
