V4 clothing to Genesis 2
I've done saving the V4 clothing I want into material presets under .duf, and after loading genesis 2 , I can't seem to merge the presets in.
I was following the instructions I found in Most Digital Creations website (I forgot what page this is located).
This is the instructions:
DAZ Studio users:
1. Load V4 or Genesis 1 in DAZ Studio
2. Load the material preset you want to use
3. Save the material preset as a DUF (File>Save As>Material(s) Preset)
4. Load Genesis 2 Female with Victoria 4 for Genesis 2 Female already installed
5. Load the DUF material preset saved in step 3.
6. Switch the UV Map to V4 (Surfaces Tab>Genesis 2 Female>UV Set>Victoria 4)
7. Save the material preset as DUF again as in step 3.
8. Close everything down and load DAZ Studio again to test
9. Load Genesis 2 Female with Victoria 4 for Genesis 2 Female already installed
10. Load the DUF material preset from step 7.
I'm stuck on step 5. Is there a different way to load the material presets?
That was for Figure textures, V4 Skin textures, you do not need to do anything to clothing textures for them to work. Just autofit the clothing as you did for Genesis1.
Oh, that was simple haha. Thanks!
How do you load the DUF material preset saved in step 3 ?
It should be in
C:\Users\Name\Documents\DAZ 3D\Studio\My Library\Presets
You have to use merge.
