Genesis Troll mouth cannot open wider.
Hello anyone,
I cannot get the mouth of the Geneis Troll to open more. I unchecked all limits on the mouth open , mouth wide, upper jaw and lower jaw dials but still it the amount of the mouth to open is stricted.
How can I solve this?
1280 x 1024 - 287K
  • Richard HaseltineRichard Haseltine Posts: 111,984
    As I recall the jaw is a bone on Genesis as it is on later figures, you would need to adjust the limits there - the properties on the ehad are controllers that drive the actual bends. I would adjust limits, rather than simply remove them, as it is quite possible that there are linkages which will cause issues without any limits applied.
  • ThatOminThatOmin Posts: 43
    Check the Parameter settings on the morph. Look at controller tab. See what is linked to that morph because you can't unlock the main morph whilst those are dependent on it. You go to Windows> Panes(Tabs)> Property Hierarchy Then select your figure Type in the search box a morph you wish to expand e.g. "Mouth Wide". Then click Parameters and then right click on that morph. Parameter settings. Uncheck Use Limits to that and anything linked to it e.g. Mouth Wide, mouth wide left,mouth wide right.... Right then.
  • OK , thanks all , I'll try it.
    cheers
