Solid state
Not sure if this is the appropriate place to post this but if not I apologise.
I have a Mac with extra Ram which I installed myself, and its pretty fast normally. However I have been trying to learn how to use Dforce and quite honestly the time it takes for anything to actually happen makes this virtually pointless. Before I began my exploration of Dforce I was thinking of upgrading my machine to improve performance and render times. My thinking was to replace the hard drive with a solid state drive, which my local computer shop tells me will show a significant increase in performance. This is the current spec of the machine...
 Model Name:    iMac
 Model Identifier:    iMac12,2
  Processor Name:    Intel Core i5
  Processor Speed:    2.7 GHz
  Number of Processors:    1
  Total Number of Cores:    4
  L2 Cache (per Core):    256 KB
  L3 Cache:    6 MB
  Memory:    16 GB
  Boot ROM Version:    IM121.004E.B00
The graphics spec is...
Chipset Model:    AMD Radeon HD 6770M
  Type:    GPU
  Bus:    PCIe
  PCIe Lane Width:    x16
  VRAM (Dynamic, Max):    512 MB
  Vendor:    AMD (0x1002)
  Device ID:    0x6740
  Revision ID:    0x0000
  ROM Revision:    113-C0170F-175
  VBIOS Version:    113-C29501-103
  EFI Driver Version:    01.00.560
I am not claiming to understand all of that info, but include it to hopefully inform the possible answers to my question. What can I change, add or do short of actually getting a new machine,to improve the rendering and performance times I am currently experiencing.
Any advice would be much appreciated bearing in mind that my tehcnical knowledge is minimal.
Many thanks
David
  • Richard HaseltineRichard Haseltine Posts: 111,949
    edited April 2018
    An SSD would improve file-loadign times, it would not help with calculation-heavy activities such as simulation or rendering (unless disc swapping were occurring, but more memory or scene optimisation would be the fix there). Your Mac does not have an nVidia GPU, and nor would an updated model currently, so you  are limited to CPU for rendering in Iray - dForce simulation would use the GPU, but the memory (.5GB) may well be limiting its usefulness.
