Genesis Starter Essentials expression morphs
Hello, I have been trying to figure out how to get the expression morphs for genesis to work. The first question I have is, what expression morphs does genesis come with? I've been trying to find individual morphs for things like "mouth open" and "brow squeeze", but I can not find them under the posing tab.
My second question is, if those morphs are supposed to come with genesis starter essentials, what did I do wrong that I cannot find them? I know there are expression packs for expressions like the evolutions expression pack, but I'm looking for individual morphs for specific parts of the face. Any help that you could give me would be appreciated. Thanks.
If you select the Genesis 2 head you should be able to find the facial pose sliders under the "parameters" tab, pose. It's not necessary to buy the expression packs - you can manually build all the expressions you need using the pose sliders.
You have to select the Head in the Parameters pane or the Scene pane, and look for morphs in the Parameters pane in the form of sliders. It usually says on the Product Page that these items do not have any user facing files (DUF), so you wont see them anywhere else but in the Parameters pane.
Thanks for the reply, but when I select the head and go to the parameters tab, there is no options for posing the mouth, brows, eyes, etc. And I'm not using genesis 2, its just the original genesis, but will the original genesis morph bundles work with genesis 2?
Thanks guys/gals, but I figured out the problem. I installed some files incorrectly. I deleted all the genesis files and reinstalled; now everything works properly. Thanks again.
