G8F to G3F pose converter that actually works?
I found out that this pose converter https://www.daz3d.com/genesis-3-to-genesis-8-pose-converter dosen't really do the job too well on some poses (figure on the right)
also the script from this one https://www.daz3d.com/bone-doctor-pose-control has similar results (figure on the left).
On this pose the values of Thight Bend Side-Side and Twist don't get copied, only Bend. On this pose it's not too bad but there are some that look very wrong.
Is there a converter that does this better?
  • BeeMKayBeeMKay Posts: 7,019
    You did use: Scripts:Genesis 8 to Genesis 3 Pose Converter? As there are two scripts.
  • DustRiderDustRider Posts: 2,911
    Quite strange. I just tried RiverSoft's Bone Doctor on a few G8 poses that have both thigh side slide and thigh twist, and everything translated quite well. I don't have a kneeling pose like yours (I have very few G8 poses), but all the standing poses translated well.
    Something else very odd is that the thigh twist parameters are changed?? IIRC there aren't any differences in the thigh twist between G8 and G3 for the convertors to change, so I'm not sure what's going on there. Have you tried other poses? Maybe it's something odd with that pose.
  • agent unawaresagent unawares Posts: 3,513
    Does the pose you are converting use pose controls for the legs?
  • Yes it does use legs spread and knees up
    Scripted pose converters don't generally transfer those.
  • Richard HaseltineRichard Haseltine Posts: 111,619
    Use the Bake Transforms (Edit>Figure menu) command on the original figure, then save as a Pose preset and convert that.
