Saving a file to disk via daz script
Hi,
Looking for a way to save a file to disk via daz scripting api, basically I want to write json data to disk, so I can run simulations externally. Is this possible via the scripting api?
  • edited April 2018
    var file = new DzFile( [directory_path, 'data', 'myjson.json'].join('/') );file.open( DzFile.WriteOnly );file.write(JSON.stringify({one: 'two'}));file.close();
    Nm figured it out ^
    Post edited by jasonayre_e56515d280 on
  • Anyone happen to know if there is a way to access the cms database via dazscript?
  • Richard HaseltineRichard Haseltine Posts: 111,867
    Moved to the scripting forum, rather than the SDK forum.
    DzContentMgr gives you access to the database.
    Sorry, that should have been DzAssetMgr, along with DzProductAssetContainer and DzAsset
