zeroing multiples?
I have a head that did not quite turn out how I liked it and it has a lot of morphs on it. Is there a way to select multiple morphs and zero them out? I tried looking on the side for reset head etc and there are a few but not for what I need.
  • Richard HaseltineRichard Haseltine Posts: 111,398
    edited April 2018
    If you right-click in the parametrs pane and set it into Edit Mode you should be able to select the morphs using standard modifiers, then right-click has (as I recall) a command to set the value. However, unless they are in a contiguous block I think it wuld be quicker to use alt(Win)/opt(Mac)-click to reset each in turn with a single click (as long as you haven't memorised their non-zero values).
  • MalusMalus Posts: 370
    Oh yeah, I totally forgot about that shortcut that resets it for you derp. Thanks.
