It's possible to convert poser weight maps to spherical zones?
CriosCrios Posts: 3,117
There's a way? A tutorial or a software for make this? We can use character as Imploo or Trollz in DAZ, or we must sit and see the other play with them?
Sincerly, there's no way to conver Poser Weight Map for use in DAZ?
    Main problem is that while you can go from legacy rigging in Poser to WM rigging, you cannot easily go from WM to legacy. By this, I mean a few clicks.
    There are a couple of ways to rig in legacy rigging depending upon the mesh. If the mesh has the standard Poser groupings and internal name configuration, you should be able to export it out and import it back in making certain to preserve grouping and naming. You can then rig it in the Poser set up room as you would rig any Poser figure. I don't know what your rigging experience is so I can't tell you how easy or hard it would be for.
    There are some older Poser utilities that can help such as PHI builder, cr2 maker and cr2 editor. These are free. PhilC sells an excellent PHI builder that is more up to date than the older free PHI builder.
    JCM's may or may not be an issue depending upon the figure. From my own experience, if I wanted to rig a figure, I'd start from scratch.
