Can't Get Genesis2 Female to Work!
I can't get the genesis2 Female to work, it's showing up in my content folder but when I try to load the base an error message comes up saying this file is missing: /data/Daz3D/Genesis2/Female/Genesis2Female.dsf
Have I downloaded it wrong, I tried both with the download manager and manually and both times it came up with the same error message
If you used DIM to install it, then it will be in the Public documents area in a folder called "My DAZ 3D Library", and you will need to add that location to your Content Directory manager using Edit > Preferences > Content Library > Content Directory Manager.
You can always use DIM to uninstall it again, and put it into the My Library folder, if that is what you normally use?
Thanks Jimmy, tried the top part of your reply and it worked a treat!
