HELP! Textures not loading on object.
I need help with DAZ Studio 4.10 . I am trying to put textures on Ptropes sci-fi bridge set ,  just the carpet for now, but no textures show up (available at sharecg for free) . All that happens is the color changes and its a flat color. I have tried non Iray using Diffuse, tiling, as well as converting to Iray , applying the Iray Base and then shaders, all types, and its the same thing. Just a flat base color of whatver texture or shader I use. I have asked others elsewhere, and they have had ZERO problems loading textures. I even tried it in Poser Pro 11 and I got the same result. I also reloaded the model and still had the same results. None of the walls or flooring take a texture/shader for me. Like I said, others have been able to apply textures/shaders to the same model so I know it can be done. I have applied shaders to other things and never had any issues. Just this model.
1920 x 1080 - 736K
  • Richard HaseltineRichard Haseltine Posts: 111,306
    Switch the viewport to UV mode (click the sphere icon at top-right, next to the button saying Perspective View in your screen shot), then select the carpet material - does it show a mesh plan in the viewport? If not the model probably isn't UV mapped, at least there, and that will not allow you to apply a map.
  • The first is view by Material. 2nd is by node
    1920 x 1080 - 399K
    1920 x 1080 - 459K
