Is the a way to shape a model with a picture of the subject
Does daz 4.10 have a way to load a picture of a subject u are trying to model? For now I am just opening daz and a separate application to view a image and just switching back and forth between applications. Seems like thered be a better way. A way to load an image of the subject into daz and set some kind of transparency to see both at Sam time?
  • MarcCCTxMarcCCTx Posts: 947
    edited April 2018
    Use the background (or is it environment?) tab to load an image. You should have the render setting/image size match the image you use or there will be some distortion. Sorry, not at my DAZ machine so I can't confirm the names of the tabs. The background tab lets you set the color or put in an image.
    BTW: I should mention it's a lot easier to model in other programs. Example: Hexagon (free), Blender (free). Or others which are more pricey (Carrera, Modo, Lightwave, etc).
    Post edited by MarcCCTx on
  • Thanks Marc. Yes easier to model but not from scratch. Started with daz and will go to free modeler at some point... Gonna miss sliders, they seem so easy when u have the right morph. Yes pricey software is just that... Pricey. Haven't heard of hexagon. Will look.
  • FelixFFDSFelixFFDS Posts: 42
    COnsider creating a plane (z-axis positive). scale the plane to your image's proportions, and then set the diffuse channel to your chosen image/photograph.  That provides a flat surface on which your image is projected.  You can then hide it/move it, etc and you have a good reference.
