Genesis XX Starter Essentials Update ??
AndySAndyS Posts: 1,449
edited April 2018 in The Commons
Hi,
In DIM I saw a lot of genesis 1, 2, 3, 8 updates for the starter essentials.
What is it about?
What did really change?
Does it overwrite modfications I did to the skin textures?
Post edited by AndyS on
  • Richard HaseltineRichard Haseltine Posts: 112,066
    I believe theya re mostly metadata updates.
    If you modified the originals, yes - it's always better to modify a copy.
  • AndySAndyS Posts: 1,449
    Hi Richard,
    yes I noticed they ever overwrite everything. So I did a backup copy, of cause.
    And I had to modify the original textures, cause every new root character should load with my modifications, i.e. colored nipples, changed brows, etc.
    BTW: Even in the latest update, still the nipples are not colored.  OUTSH !!
    DAZ really should think about to adapt the current standard (of the later generartions).
    Could someone please list in detail, what was changed on the latest update?
    AndyS said:
    Hi Richard,
    make modified copies, apply them, and save as a character preset - then use that to load the figure instead of the Daz preset.
    http://docs.daz3d.com/doku.php/public/read_me/index/14812/start#resolved_issues
    http://docs.daz3d.com/doku.php/public/read_me/index/16280/start#resolved_issues
    http://docs.daz3d.com/doku.php/public/read_me/index/21630/start#resolved_issues
    http://docs.daz3d.com/doku.php/public/read_me/index/42071/start#resolved_issues
  • Silver DolphinSilver Dolphin Posts: 1,657
    Yeah, I always mod everyting that is why I back everyting up!
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,843
    is a double xx update milder than a triple XXX one? cheeky
    I guess you cannot  modify  those textures as they don't exist in essentials
  • PadonePadone Posts: 4,377
    edited April 2018
    It is not clear to me what "added anatomical elements UV set" means. AFAIK the G1-G8 basic characters don't have anatomy at all. So how do you add uv-sets for something that's not there ?
    Will previous/third party textures compatibility be broken by this update ? Either way I believe at the very least DAZ should state it clearly in the release notes. Such as "this will/will not break compatibility with previous textures".
    Personally I'm most concerned with "body" textures since I rarely use anatomy itself. Of course I'll do some tests myself with the new update, and if I find out that it breaks compatibility then I will just go on with the old G1-G8 set.
    Post edited by Padone on
  • AllenArtAllenArt Posts: 7,176
    If you've ever bought a pro bundle of any generation then you have the gens for that gender in that generation. The gens come only with the pro bundles.
    Laurie
  • ImagoImago Posts: 5,817
    An update but G3/8 IKs are still broken... When they will work like Genesis 1/2? If I pull G1 hand, the whol arm folds and unfolds the right way, G3/8 bends his chest awkwardly! crying
    Laurie
    I just downloaded the new update and I can't see any difference in the G3 and G8 uv-sets. They're not changed so compatibility should not be broken as far as I can see. I still have no clue what the new anatomy uv-sets are for .. since there's no anatomy in the base figures.
    did they fix the individual toes?
    clicking the eyeicon make left big toe 2 invisible?
    tysmiley
    tysmiley
    Not broken in the first place, just didn't do what you wanted. I thought we'd used the Geometry Editor to get the desired behaviour?
    i submitted a ticket on it.
    if they fix those root regeons mebbe g8f will work in carrara.  g8m is getting lonely, unless, he seeks company in another g8m
