Problems with transfer utility and genesis 8
Hi everyone, i'm trying to create a shirt with marvelous designer for a genesis 8 character, but when i use the transfer utility, the shirt raise up as you can see from the picture. Using a genesis 3 model, this does'nt happen and the shirt fits fine, what's wrong? Please someone could help me? Thanks
907 x 453 - 80K
  • Richard HaseltineRichard Haseltine Posts: 111,718
    That looks as if you have morphs applied to the figure - is that the case?
  • Yes, there are some morphs applied to the character, that means i can't apply transfer utility to this? I also tried to build a simple poncho with marvelous designer and fit onto the base genesis 8. In MD the poncho fits perfectly on the model, but when i import it in Daz, the poncho doesn't fit on genesis 8 base model, also before to apply the transfer utility. I found few tutorial on YT, but nobody used the transfer utility on genesis 8 yet. Maybe a issue with genesis 8, or it need different setting in import/export?
    Morphs at least requier an extra step. Set the Source Shape to Morph, then select the morph you used, or if there are multiple morphs try using Current - once you have that, expand the More options list and check Reverse Source Shape from Target. That won't always work, it can't handle transforms (transltion/rotation/scale), but it may be all you need.
  • GREAT RICHARD!! It works! Thank you a lot.wink
