Collada export gone?
I remember that Studio had an option for .dae export, was it removed?
I'm not sure because I haven't used it for a while, but I do not have the option in my export dialog, in fact, I can only export as .obj, u3d or fbx. I remember more options there. Is this something to do with the new Genesis figure?
My export dialogue gives me MDD, BHV, dea, cr2, obj fbx, and u3d as the possible options with G2
The export option for DAE is there in mine, no matter what is loaded or selected. You may need to change to another Layout briefly, then back to your own to aee all the options. It sound like a video card issue.
That seems odd, why would your videocard, or layout you choose affect what export options you get?
The layout sometimes gets corrupted.
The way to fix it, is to load another layout, then go back to the one you normally use. Not all layouts have the same options anyway, the Beta one has very few I think.
Thanks for the answers. Sadly, I can't get the options no matter what layout I choose, I guess I should try a reinstall.
Have a look at your plugins to check if you have the Collada exporter. That may be the problem
That was the problem, a good portion of the plugins were disabled, but they wouldn't activate after restart, so I had to reinstall.
